Status
Not open for further replies.
Sled How-To's here!
153K views 60 replies 48 participants last post by  halltm
#1 · (Edited by Moderator)
Like to tinker with your sled? Here are some links to help!
Used sled evaluation guides
Used sled buyer's checklist
Wanna know what chassis your sled is on? Listing here- ALL brands!
Chassis List
Wanna know how to check your sled over before the season starts? Check out these Pre-Season Checklists!
Sled prep 1
Tech - Snowmobile Encyclopedia - Snowmobile Encyclopedia
Here are some how-to's to help you save time and cash by doing it yourself!
TPS sensor testing
How to Troubleshoot a TPS sensor | eHow.com
Fuel System:
http://www.snowmobileforum.com/engine-drivetrain/64230-how-mikuni-carb-works-detailed-video.html
Jetting basics;
http://www.snowmobileforum.com/engine-drivetrain/55800-jetting-bottom-top.html
http://www.snowmobileforum.com/engine-drivetrain/54451-cleaning-mikuni-tm-rack-style-carbs.html
How to make a homemade carb synch tool
Hard starting engine?
Carb Rich vs. Lean Symptoms
Carb Cleaning
Mikuni round slide and fuel pump rebuilding
BC-Dan's Carb Clinic 101
EVERYTHING you need to know about how Mikunis work!
Mikuni Carb size chart
Mikuni VM round slide carb manual
Tillotson HD carb diagram/rebuild guide
Tillotson HR carb diagram
Walbro/Tillotson diagrams and tuning
A WalBro carb fix
Login
Arctic Cat throttle switch override how-to
Piston Diagnosis
Clutches/Driveline
Belt maintenance link.
Click in the power point link on the page.
Ultimaxbelts Media
Olav Aasens clutch tuning book.
http://www.scribd.com/doc/30484148/Clutch-Tuning-Handbook
Clutching IQ
Clutch Theory/Calibration
Clutch Removal, cleaning, etc.
Secondary clutch repair
Clutch cleaning Advice by RJGleason
Speedometer quit? Check these things!
Ski Doo Clutch Spring Colors
Track Changing
Driveshaft Bearing Replacement
Got a stuck/spinning skid bolt? Try here!
Track fitment guide (bottom of page)
JBShocks Tech Pages
Engine/Miscellaneous:
Build your own leak down tester.
how to do a leakdown test - powersportjunkies.com
VES Valve Cleaning
RAVE Valve Cleaning
Priming your oiler system
Airbox Mods
Rotax Rotary Valve Timing
Seat Recovering
How to polish your tunnel to make it shine!
Ski Doo operators manuals
Yamaha Trouble Code list
How to build a ramp for your pickup
Power Sports Resource
Vintage Snow
How to fix a broken Recoil
Torque specs for anything.
Snowmobile lift plans
LED Installations
A little interesting reading to take up some summer time!:
http://www.southernskies.net/page_info/runningtwostrokeengine.html
2-stroke porting article
Two Stroke Piston Diagnosis
Stator problems?
More videos for Cat stators- like how to bypass a bad wiring harness!
Save
#6 ·
smallengineguy thanks for the links for the sled maintenance. They will help me greatly on getting this sled ready for this winter. I printed everything out:thumbsup:
Save
#8 ·
Thanks for the info!
Save
#19 ·
Awesome post small engineguy!
Hey thanks for that great info on generel sled upkeep and tinkering. I find it fun to work on your ow sled and then feel it run smoothly on the trail. I just got back into sledding again and bought a 96 Yamaha Phazer and found out it had sugar in the gas tank! I took the tank off and flushed it as well as gas lines and cleaned carbs. However I cannot help but wonder if any engine damage waas done , I ran it about 200 miles before noticing and who knows how long the previous owner ran it that way. What are your thoughts???
Thanks,
Brad
#20 ·
very cool!
Just joined the forum yesterday, just kinda clickin' around seein' whats up. Lo and behold a section with wrenching info and tuning help for us who like to work on sleds but may not know it all. Like a shop manual with no front or back cover, just endless pages of info in the middle. This is a great feature that I have not found on other forums I belong to. This is one section I will keep bookmarked!! Thanks!
#21 ·
Great post SEG. i just picked up an 89' Phazer that runs, but i wanted to make sure it was in tip top shape before hitting the trails this winter. thanks alot for the info :)
Save
#26 ·
Status
You have insufficient privileges to reply here.
