i picked up a tilt and swivel trailer frame for 50 bucks. i put new wheels and tires, toungue, safety chains and led lights. putting deck on it this week, but heres my prob. i assume the idea is to, for unload, unstrap the sled and back it down the now tilting trailer? does the trailer tilt gradually as the weight of the sled is moving backward past the pivot point? ok, so now the sled is almost off the trailer, the only thing holding down is the skis. once the sled is free, the trailer/deck will slam back to the "normal" driving position? same as loading? basically im looking into preventing such a loud blunt crash noise when the trailer slams back into place. im thinkin either mounting some sort of shock on the draw-bar under the deck of the trailer. once you pull the pin to unlock the tilt function its now free to spring "open", but since the sleds on it it wont tilt. you/i should be able to compress the now shock mounted deck back down and lock the pin. load time. pull the pin, trailer springs to tilt and holds deck in position to line sled up and drive on. now this is where i hope the shock does the job of "gradually" lowering the deck,with sled, back to normal position. did i get of topic? sorry if i did. any other ideas out there guys?
