84 polaris ss 440 help please!!
3 reading
5.1K views 15 replies 3 participants last post by  RJ Gleason
#1 ·
my 1984 polaris 440ss has twin cylinders and 1 carb.
my problem; running on 1 cylinder only? (flywheel side)
heres what i have done;
checked spark and seemed ok on both plugs,switched plug wires and seem to run abit better.(still the same side only; CDI maybe?)
checked comp. and same on both jugs.
getting lots of gas on the dead cylinder spark plug
but it puffs out some smokewhen i pull out the plug?
pulled the head off and the piston looks good and is tight to the jug(alot of carbon build-up).
cleaned the carb.
what am i missing? is there a timing issue, maybe a new CDI box?
HELP PLEASE, THANKS, dew
#4 ·
it will run with throttle opened up but wont substain a high rpm, also it wont idle. ill let it run awhile and the left clylinder is cold. pull the plug and a bit of smoke rolls out and the plug is covered with gas.
i switched the plugs and put different plugs in and no difference.
but it seems to run alittle better when i witch the wires from the cdi but stll the left cylinder is dead.:mad:
not seeing any leakage from the crank bearing on the clutch side
is it firing on the wrong revolution?
is there a way to check the CDI ?
thanks for the input and keep it coming. not sure were to check next!
dew
#6 ·
thanks for the quick reply!
im gonna try that cuz i have no idea what else it could be?
but seems a little odd that when i switch the wires still no firing in the left side, but im not sure if thats the route to take when checking for good spark.
and i dont know how the CDI pack functions.
any suggestions were to buy one,
thanks again, dew
#7 ·
#8 ·
i'll try that, thanks.
also how bout the reed plate and were is it?
maybe clogged muffler on that side?
seems to me if i swithced the plug wires why would'nt the other cylinder fire?
keep the suggestions coming
thanks again, dew
p.s. gonna be cold here in iowa(-15) to work on it but gonna do it
