There have been a few guys asking about cleaning the VES valves on Polaris sleds. I looked in some of my pics and have these to share...
First off, there are two bolts holding the VES valve assembly to the cylinder. Remove those and remove the valve body. If you're careful, the gasket may stay intact. Have two gaskets on hand in case you're not lucky.
Here's what the valve will look like on your bench...
Remove the two remaining bolts. Inside will be the bellows and a spring. The spring side of the bellows should be clean, the underside will be coated with very dirty oil.
Remove the valve cap from the guillotine. I find wrapping the guillotine in a towel and putting it in a vise to hold it works well. That should leave you with all the parts disassembled.
Clean all the parts, replace old and worn bellows and springs
Assembly will be continued
