question on how to put on the drive belt.
1 reading
1.3K views 6 replies 3 participants last post by  tbennett23
#1 ·
I have an 1995 indy special xlt 600, and i need to know how to put on the drive belt. Can anyone walk me through it????
#3 ·
Here is a bassackwards way to do it...
Set the belt around the secondary clutch. Grab the secondary clutch outboard sheath. Rotate counterclockwise. This will allow you to open the clutch up and the belt to slide down towards the center. Hold on the the secondary sheath with one hand while you slide the belt over the primary clutch with the other.
Ta daa!
Any other way to make it hard?
