Hey Phazer fans! I just cleaned up some wiring mess on my 88 Phazer that the previous owner had created. I replaced the wiring harness, and removed the aftermarket hand grips/warmers and the mess that went along with it. I just received the OEM hand grips/warmers and wires attached, but I'm not sure what wire I'm looking for on the harness that comes out behind the plastic shroud at the steering column.Any help? Also the directions that came with the hand grips recommended an in line resistor. Is this necessary?
