I have a 1987 Yamaha Exciter, that has set for a few years. I went through the carbs and cleaned them the very best I could. The snowmobile started and I ran it through the yard. Everything seemed like it was good and it idle great. Put it on the trailer to get it out for a long ride in a week. The wekend came and I was going to start it and it wasn't starting. I noticed some serious gas coming out of the exhaust pipe. I pulled the plugs and their wet.
I tried to do my research on this issue, I'm a bit new to carburators. All the forums on this said it was the floats or the needle seat. I pulled the carbs again and the floats seemed fine. I removed the float arm and pin and then the fuel inlet needle and seat. Cleaned and air blow. The needle seems to move up and down freely. I did this the same on both carbs. They both seemed the same. I put the carbs back in and gave it a pull, the sled fired over and quickly shut off. I then pulled a few more times and I could see gas dripping from the exhaust. I didn't even use the choke.
I'm stumped. The sled idle great a week ago and now I'm having the same issue after the second cleaning. I realy don't know where to go from here. Any ideas would be much appreciated.
