Alright, the other day i was out test ridin my 98, I just went through the carbs and jets like i always do every year spraying them with carb cleaner and what not to get all of the build up out from condensation. I was givin her hell for a while, came back shut it off and took a break for about 10mins. i started her back went to take off and the belt slipped, so i shut it off open the hood and there was coolant sparyed out all over my belt cover, far left cylinder and carb. I checked all hoses and found nothing, and i dont think its the water pump because its located on the other side of the motor. Its not stock, i has PSI pipes,clutching and is bored out a little. I dont no what it is but it sounds like there is coolant in the pipe. Can anyone help me out?
ZR rider
Probably sprayed out of the cap. It could be air in the system, in which case you need only elevate the front end higher than the rear exchangers and take off the cap then let it idle for a few minutes.
