YEEEE HAAAA!!! Got it runnin! Felt good to grab a handful and stand it up on some hardpack. I reek of sled exhaust and liking it.
I took the kids for a ride around the field near my sub. Fun fun.
I replaced the two check valves and put the motor back in. I left the injection lines disconnected from the cylinders and mixed the fuel. I then started it up and let it idle. After pulling on the pump arm, oil slowly pumped from the lines. I'm not sure if the injector is still leaking but I know for sure my oil pump works. I connected the lines back up and dilluted the mix in the tank with about 5 gallons of fuel. A little extra oil won't hurt since my motor is fresh with new pistons and rings.
