anybody know how many MM the stock carbs are?
How big are zrt 800s?
Where is the cheapest place to have my stock carbs bored?
The zrt 600 has vm36's on it and the zrt 800 has vm38's the same size thats on my '92 550!
you can get carbs bored? i would just buy new ones, if there was a reason for it
yeah you can get your carb throats bored but you need to make BIG hp #'s for it to make a positive impact. Putting bigger carbs on slows down the air intake velocity and decreases hp if not needed. Theres a reason a/c put smaller carbs on the 600;)
four gear pinned
yah unless you have sent your motor to a aftermarket company for a port and polish, twin pipes and are runnig v froce reeds, a carb bore will do nothing on the preformace side. start somewere else like clutching.
