ZR580 Bogging
  • gas line clog
    Votes: 1 100.0%
  • running rich
    Votes: 0 0.0%
  • jets off
    Votes: 0 0.0%
  • water in carb
    Votes: 0 0.0%
I need some help. I ride for a few min, then it starts to bog alilo, like its loading up. then it will kick back in and go. it stalls out sometimes, and i dont know what to do. it could be a plugged line, running rich from too much oil entering, or suttin else. please help!!:confused:
try checking for water in the floatbowls a freind has to dump his about every ride no matter how much drygas he uses
good luck!
check the plugs, black = rich, white = lean, brown = perfect, that should either give you the answer or take a possibility out of the pool you have going. good luck.
