Hi Guys, I am new to this forum. I just bought a 98 ZR600 that has just had a top end rebuild. the guy says that he has not bled the cooling system yet. He mentioned a special cap to do this. Does anyone know the procedure for bleeding the cooling syste?
Thanks, Ray
Keep the front end of the sled higher than the back end to get rid of any air pockets in the heat exchangers. then run it with the cap slightly loose for a couple minutes. The water pump should bleed the system. If it starts to overheat, there is still air in there somewhere.
