95' Polaris Storm 800
Does anyone know if I am going to run into any problem with replacing a Gen ll polaris chassis's xtra 10 with a wedge style's xtra 12? Same size track and everything, just wanted to check. Also I was told that if I was going to replace a 95 Storm's xc-100 with a higher one I should only use an xtra 10 because an xtra 12 would result in overheating. Any advise?
Discussion Starter #2
anyone?
hurry up winter
every thing is different on the front end if you managed to get the skid in the ski pressure would be to much and as for the front end the xtra12 has longer trailing arms which are mounted further back and radius rods along with an extra piece on the upper shock mounts it would be a big job and lots of relocating mounts personally I would stay with the xtra10 hope this helps you out
