1 - 12 of 12 Posts
I just picked up a 96 XLT Spiecial. It has the 600 in it. I ant to take off between 4800 and 5000. Does anybody have the setup in there sled. If so can you tell me what color spring you run and your wieghts. I have a blue spring with 10 mr weights kicking around, would these be able to do what i want them to do. Thank You Very Much
my 97 XLT engaged at 4800 with a gray primary, sorry I don't know what weights. Light blue secondary and it really ripped. It was like that when I got it, I wish I could give you more specifics.
If you have a decent spring in there now giving you fairly aggressive launches and shifting , just drop a couple grams off the weights to get a higher launch RPM.
Lighter weights require more RPM to overcome the spring tension.
A heavier weight would overcome the same spring easier, thus lowering engagement RPM.
1 - 12 of 12 Posts
