which gears do you all run for 1000 ft drags in your 600. I'm running a zl 600 efi with a clutch kit I put together. But i'm wondering what will work best. I do believe I have stock 22/41. Joey
back in the game
just going on common sense, but I'd think you'd want the sled to run out of pull right at the end of the 1000ft, or even around 900ft or so, depends if you can get all your power to the snow, I have no clue what ratio would that be.
but if you figure your speed at the end of the 1000ft, and look at your RPM, then you should be able to figure out a decent gear...
I would leave the gearing alone. If your clutching is dialed in then you should be fine. Gearing down twins isn't like the old days of gearing down the tripples.
