new to me indy 500 1998...manaul says preload should be set .8 inches up on mine it is nearly 3. Dealer says "thats normal for those sleds, you had to have the preload cranked all the way up for them to work"
Seems like if that is the case, there won't be much movement in the shock at all. Right now when I sit on the sled the front end doesn't even budge. Would I not get a better ride with the pre load reduced so I get some travel? Right now when I try to turn I slide like crazy.
Appreciate the help.
