Just ran a compression test on my 700. I let the motor warm up for about 3 minutes then did the test. Exactly 120 psi in each cylinder.
What do the test at new?
Is my 120 psi good?
That year has 120psi to 130psi per cylinder.That year and 00,01 had 120 to 130 psi so your right where you should be.That's a good place to start to gain extra hp.Up the compression and it will help you out.
