1 - 9 of 9 Posts
· Registered
Hi guys,
Haven't been on here in a while, but I am moving to Peoria IL and going to get snowmobiles. I have 2 dirt bikes, and work on many peoples lawnmowers/small engines so that's what I will be using the trailer for and of course the snowmobiles. What size trailers do you use I am wanting a open air trailer with slide out ramps or the ramp that folds down. I think I would need to be at least 6 ft wide by 10 ft long to fit snowmobiles on it? Would this work for 2 snowmobiles? Do you have any pictures on what you guys use or info. Yes I will install a salt shield so that won't be a problem.
Jake
· Premium Member
Six ft wide will not accommodate two sleds side by side.
Seven and a half to eight is necessary for that.
An enclosed would also allow you to carry tools so you could even do some minor repairs on the spot.
· Registered
What if I staggered them like ones skis all the way at the front and the other faced backwards (skis facing to road) pushed up to the middle or up farther?
· Registered
Anymore Info or pictures of your trailer would be awesome!!
· Registered
I think this could work and just put them sideways and let there skis hang over the top rail. I would put a mesh ramp on the back. Would I be able to put 15'' tires on it?
atv trailer
1 - 9 of 9 Posts
