1 - 20 of 36 Posts
So I'm too lazy to go out and buy a bottle of starting fluid, so I'm wondering if you guys know of anything that works just as good as starting fluid (besides carb cleaner) and doesn't hurt your sled?
SD Rider
Premixed gas from lawn equipment, chainsaw, ice auger, any kind of premixed gas will work great. Make sure it's premix or else it'll dry out the cylinder walls if it doesn't start, which isn't good. And for starting fluid, make sure it has upper cylinder lubricant in it for the same reason to use premix gas.
Rick
X2. i try to stay away from starting fluid.
Yeah I'll be sure and try that, and yeah I always use starting fluid with the upper cylinder lubricant. I rarely use starting fluid, being that my sleds are always in good running condition and don't usually need it, but I'm working on a new sled that I just bought and it needs a good fuel cleaning.
Rick
sea foam. i love that stuff.
SD Rider
Seafoam and Sta-Bil are possibly the greatest things man has ever created, besides snowmobiles of course. We try stay away from starting fluid too, but sometimes it's easier since it's in a can and you can spray it directly in, no trying to find a funnel of some kind of just trying to pour it in then you get gas on the heads and it's a lot easier to just grab the starting fluid and spray it in, although I try refrain from using it.
mans 4 greatest creations. in no particular order
WD-40
SeaFoam
Stabil
Duck Tape.
Rick
I'd use a pump type oil can with premix in it!
thats what i use also. I tried a old spray can. yeah that lasted about a hour. lol
the reason i steered away from starting fluid was cause the can... my colt never would start regardless of how i set the choke. so i relied on starting fluid. well when it gets below a certain temperature spray cans loose their pressure and ability to spray... needles to say i spent one sucky afternoon hugging a frozen starting fluid can close to my stomach so i could start my sled after a day out ice fishing... after that experience i have always torn apart carbs and cleaned/tinkered with them till they will always start 100% with the choke and never need starting fluid
so there best alternative is figuring out the choke... but i like the idea of an oil can and the next time i need any starting fluid i think i will put 2 stroke into an oil can and give her a try
Vintage Racer
Anybody else ever use that non either starting fluid? Man is that stuff temperamental and on some motors it will just do nothing
i was poking around my garage a while bck and in my dads old car i found a cans all white so i sprayed a bit and i didnt know wht it was weel tht day i happened to be working on somthing i reached for starter fluid and grabed the white can by mistake and first try fired right up ran for a while i was kewl then i realized i grabed the wrong can i flipped i went to my dad and told him he said No problem dnt worry bout it i asked wht it was he told me its a secret so i still dnt know im gonna find out 1 of these day but ive benn using it for about a year best stuff ever lucky he had more than 1 lol
SD Rider
Hairspray would probably work...and if you're married I would bet your wife has some in the house somewhere.
IDK about hairspray...
I think you need something that burns more stable then hairspray. although it does burn very well. I can attest to that lol
1 - 20 of 36 Posts
