Team Arctic
today i was riding home from a friends place and right out of no where i hear this big clunk. so i start slowing down and i could see the secondary moving back and forth on the jackshaft. So as i got stopped i shut it off and opened it up. Sure enought i fing that the bolt has come out of the shaft. so i grab it and as i was reaching for it i found another nice little present, one of the arms on the spider was laying beside the bolt, and a wieght. The spider must have been cracked because it broke pretty clean off and when it broke the wieght must have snapped to. :( So now i'm to the stage off what to do with it. i've only had this sled a weekk and already so much has went wrong... i hope this is the last fix i have to make. When you are putting on one weight you shoudl probly change all three right? and the spring while you in there anyways... Well i guess i just had two little questions sorry to bore you. Answers welcome.
Yes, replace all 3, as well as the spring and the bushing that the one side of the secondary rides on. A lot of times this causes the problem by making the sheave open crookedly. It's pretty easy to replace all these parts.
Team Arctic
thanks, i think i will just be replacing the whole primary clutch. If i can find one - backordered till march 15. I think i'll take your advice and buy the bushing too. is it like a long cylinder?
Team Arctic
thanks for the advice, i found a clutch today too so i should be on my way in couple of days anyways, depending on when it gets here.
Runnin Against The Wind!
I don't mean to be negative, but a friend of mine who had an Artic cat had constant clutch problems over and over and over, not to speak of the other problems. He finally purchased a Yamaha and has been happy ever since.
Team Arctic
i know, every brand has their lemons though. We've been runnin cats for about 7 years and this is one of two problems we've had, on one of our old 95 pumas we broke a crank and now this clutch. I got the new one this morning, also found out that someone had chaneged the wieghts from stock. i might buy a clutch kit for it, not sure yet, this clutch was enuf money already.
