I have a 94 Indy Sport with a xtra 10 suspension upgrade. Its very light on the skis and I want to get some pressure on the front so wife can drive it. TIA
Xtra 10 on the front too? It must need the front track shock loosened or the limit straps tightened. I run my limit straps very loose. It sounds like you don't have the Xtra 10 on the front.
No they just swapped out the rear suspension. I bought it with crank gone. I rebuilt the engine and the sled pulls good but very light on the front.
Are the springs in the front adjustable? If so, increasing the spring pressure should increase ski pressure.
You can also loosen the front shock pre-load or shorten the limiter strap, but that may affect ride quality. Try adjusting the front springs first.
