I have a 1998 Polaris RMK 600 that I am putting back together. The water pump was shot so I took it down to the Polaris shop to have the bearings and seals pressed off and new ones back on. I didn't leave the impeller with them. Once I got it back, I went to put on the impeller on and torque it to the the 10 ft/lb required and found that the impeller now rubs on the inner casting of the housing making it difficult to turn the drive spinning the impeller. What should the clearance be between the impeller and the housing casting? should I shim it out with another washer or take it back in and see if they can press everything a fraction of an inch more to put the shaft further into the water pump housing?
Thanks for any input and your time answering!
