great site here !
Not sure how it got in, but I found water in the system, carbs, tank, pump, etc. got it all out, cleaned everything up and am putting it all back together, before I hooked up to the carbs I ran the 2 fuel lines into a container, cranked it to pumped fresh fuel threw the pump (elec start) to see if there was water in the pump too. what I noticed was that one side doesnt pump as well as the other, they both filled but only one side would push the fuel out, the other would just move in the tube. if I kinked the working side the other would then start to push fuel. are there any servicable parts in the pump? what considerations are there with the oil injection involved with the pump if I need to disconnect it to work on it?
Would you say there is a problem with my pump?
its an 02 570 panther
