hi everyone im new here and first question i have 95 650 efi my head and tail lights sometimes are bright then go dim but never go out could this be voltage regulator or internal on stator plate any replies would help thanks:dunno:
Check the voltage regulator ground. Pull regulator off, sand the body where it mounts as well as he back of regulator and maybe another metal shim and the ground wire end and put it back together with a little no-corrode or dielectric grease.
it looks like 3 of them one near headlight another near key switch and bigger one under airbox/ throttleboddies also what is dropping resister :dunno:
