Is the Voltage Regulator well grounded? Does it have a metal case? The case needs to have a good solid connection to the frame.
Yes I even sanded the frame down behind the regulator.Is the Voltage Regulator well grounded? Does it have a metal case? The case needs to have a good solid connection to the frame.
I'm not sure if the bad battery was caused by the reg or the reg killed the battery.Welcome
Why did it fry reg?
Could you have a short?
Or bad stater
Thanks. I will try swapping the yellows on the regulator and see what happens.Maybe the yellow/Yel-Blk wires are backwards on the regulator?
I know that when I've seen 3rd party regulators connected backwards, it does exactly what you describe.
3rd party VRs usually just have different colors for the wires. Like Red, Black, Green, Yellow. Skidoo ones are Yellow-Yellow/BLK and with e-start they have a red wire.
Ok I'll try that this week and report back.Try running a new separate ground wire from like recoil on motor to where the regulator bolts on.
Yes even after tracing wires and adding/cleaning grounds I tried 2 different kimpex regulators and both had that issue. Found another brand of regulator and it fixed the issue for me. Seemed like faulty new regulators.Has this issue been solved yet? I'm having the exact same problem on my 97 Grand Touring SE. My old regulator stopped working and voltage was too high, burned out headlight, etc. I got an aftermarket replacement, same exact issue as this, about 12v at idle with lights flickering, then voltage drops to 7 or 8v when you rev it up. Help!
Thanks for the quick response, that's so strange. I guess I better look into that then, thanks.Yes even after tracing wires and adding/cleaning grounds I tried 2 different kimpex regulators and both had that issue. Found another brand of regulator and it fixed the issue for me. Seemed like faulty new regulators.
