1 - 9 of 9 Posts
Daniel
K so I went to change my belt the other day and I found that my jack shaft support bolts on the clutch side were all loose and it was moving up and down, I fixed that but my sled still has a vibration when I pin it, does it sound like that bearing was destroyed by all the movement or am I looking at something else? I feel the vibration in the seat and handle bars if that helps, the engine seams to run fine so I don't think it is vibrating
Any suggestions
ZR rider
Does the speedo still work?
Daniel
My speedo reads but I can't seem to get it above 70mph, I'm not 100 percent but I'm pretty sure I'm going faster than that. If that's the case what is it? And how do u fix it?
If you have a thundercat it will be at 70 real quick and beyond,look in the how to section in the index of this forum it tells how to do it or in your manual if you have one.Im getting ready to do it the first time myself
Probably the jackshaft bearing...
ZR rider
Well the bearing is probably worn from that vibration so it can't spin like normal and your speedo is only picking up part of your speed. Replace that bearing.
1 - 9 of 9 Posts
