I just purchased a used 2002 mxz 700 sport. Being used it of course needed some maintenance and I found a large crack on the carb intake flange, I've been told the 2002 mxz 700 sport cannot just have the intake flange itself replaced, but instead it has to have the entire reed, cage, gasket and flange itself replaced. I also cannot specifically find information on the mxz 700 sport regarding aftermarket v force 3 reeds, part numbers etc.
Does anyone have any information on where I could locate some aftermarket replacement reeds, either v force or boyensen? Doesn't matter unless there's some huge difference between the two. I don't really want to use oem stock parts unless I have to, because according to my local dealer the intake flange can only be replaced along with the cage and reed valves at a cost of nearly 350 dollars. Are there no aftermarket parts that I need for this sled? If someone has a link or specific part numbers I could check on please let me know. Thanks.
