Allright this is really confusing.i had my snowmobile running and then i drained my gas tank then i started her up (73 prowler) to drain the lines but then i decided to do some work on it and filled the tank back up with fresh gas and new plugs new battery and when i went to start it, it wont start i have spark and the engine is not seized it turns over and i have gas to the carb. i took my air box off and sprayed starter fluid right down the carb intake and it did nothing any suggestions?? im stumped
Squirt fuel into the carb throats. If it starts then stalls, then you have a carb problem. Try that first.
