One of the holes on my tunnel where the suspension bolts on( in the rear) has ovaled out slightly. Is there a fix to that?
The BEST way is to rivet a 2" by 2" steel plate with the new bolt hole over the old one. I've seen people use JB Weld to fill the hole and re-drill it. Strong stuff. Make sure the bolt is TIGHT this time.
Chances are the cross shaft is siezed in side the cross tube from lack of grease or rust. That is what usually causes the bolt to back out and wobble out the hole.
