Maritimes Guy
any of yas ever change stock settings (number 2) to number one inside helix?? i cleaned my clutch today, and while I was at it I removed 2 flat washers from in between sheaves(causes they werent closed all the way).
seems like its geared to pull an elephant now??
I was riding in warm conditions, deep wet snow last year and changed mine one hole to gain more low end for the day. It did do what I was intending, but I had to be very carefull not to let it over-rev. It blew up that day anyway!!! I found a cracked carb boot that looked to be the culprit though. I wouldn't leave it that way for very long.
Maritimes Guy
Put spring back in original position, but put a clutch from an 89 500, wich I beleive has a 34 degree helix instead of 36 degrees in my original.
Suppose to have better low rpm power right?
Maritimes Guy
follow
