Looking at getting a 1 1/4" predator or ripsaw track for my 2000 SX 700r. I've heard two different opinions on whether they will fit or not. Will they hit the front heat exchangers or tunnel?
Would I have to make any changes to use either of these tracks?
I just finished installing a 1 1/4 ice ripper on my vmax which is the prestudded ripsaw it will fit but if you have the cooler protectors on your front cooler there is a lug pattern about every third row on that track that will slightly rub those protectors its not really close to the cooler because those protectors are very thick so I just took a razor knife and trimmed the lugs on the rows that were hitting. its pretty easy since its only like every third row that hits.
Thanks for the reply Jerrys1.
I looked at it and it has the protectors on the front.I wasn't planning on studding the track at all. Maybe I'll think about going with a one inch instead. Going to have to think about it.
After talking to the guys at the track place I went with the Hacksaw 1 inch fully clipped and pre-drilled.
I may decide to stud it after since its a 1 inch.
