21 - 27 of 27 Posts
That tunnel looks hacked up! At least on my rx1 warrior tunnel, every hole has a bolt or a rivet. There is a purpose for every one of those and it isn't ventilation, most are structural.
I would definitely see if I could get a pic &/or measurements off a factory rx mountain and move the skid to match.
(my rx1-warrier 136" for comparison, although different skids so it won't help you on location)
Tire Wheel Automotive tire Vehicle Combat vehicle
It really isn't that hard. Put the sled on the ground and take a ratchet strap or two and tighten the suspension up. Once that is done, lift the back of the sled onto a stand of some sort. Remove the 4 mounting bolts, measure back 1.5 inches or so on each, drill a suitable sized hole, and reinstall.
They key is to try to compress the suspension as much as you can BEFORE removing it. If you don't, you will have a fight on your hands to get it back in.
I definitely wouldn't run it though. At best, the track is going to skip and ratchet under load, which will eventually destroy potentially your track and/or drivers. Worst case, see coolhands post above.
21 - 27 of 27 Posts
