1 - 14 of 14 Posts
I have a 99 V Max 500 sx, and I noticed at very low speed under a load(not on a stand) the track seems to be jumping. First I checked my track tension, thast was fine, next I replaced my whole drive shaft w/ new cogs and new bearings and it is still having the same issue. When I had everything taken appart the chaincase appeared clean with no shavings and the gears looked solid. Can someone please help?
ok i just had the same problem sounds like the wheels are jumping the track if im right i thought its was them checked all good got it apart why not change bearings check put back together same problem then i realized when i was putting the skid in that it was piece of cake thats when i realized clips were only on have the track on the one side and the reast on the other be sure to check all clips are there no more then like 4 5 inches apart on older tracks and you will notice were they would beon newer tracks
in addition to the track tension, is it aligned as well? could be running off to one side. check for equal distance from the rails/sliders to the inner track lugs.
your chain tension is too tight! finger tight the long adjuster bolt, the jamb nut is set at 17ft lbs. take a closer look at the manual, you will see what i mean.
depending on what book your using, the track alignment procedure will be covered as well. seriously, doublecheck your chain tensioning procedure.
last thing to do is put on a known good belt or new belt and see if the issue doesnt go away.
it wouldnt but maby your mistaken just check it anyways to make sure your clutch is working or there isnt a chunk of belt making it seam like the track is jumping atleast you will know for sure all is well in that area after ya check it
Discussion Starter · #9 ·
Problem solved
This may be a dumb question, but, how would a belt affect the track jumping? I'm just asking because this souds a lot like the problem I am having.
I feel like an idiot but it was my belt. And my spare belt that was on the sled when I bought it was said to be new did the same thing so that's why I did all the other work. I went up to shade tree bought and put on a new belt and the problem has been solved. Although I did do alot of good maintenece on the machine.
As to why a belt can cause the problem: if smoke or burn up your belt even just a little you create a area of the belt that is thinner or more narrow(hard to see with the naked eye) and it will cause your cluthdraw in a little then it hits the wider normal part and it "jumps".
Discussion Starter · #11 ·
WOW, I'll have to try that, too. Thanks for the update!
You can check it before you buy a new belt. Get the rear on a stand. Set your parking break, or hold the break if you don't have a parking break. Rev your engine with the clutch/belt cover open. Watch your primary clutch if while reving the engine if you see the clutch kind of jerking a little (speed wise)
get yourself a new belt. Make sure you break your belt properly.
Discussion Starter · #13 ·
Usually there are instructions on the inside of the jacket that comes around the belt. But if not I usually go about 10-15 miles not over half throttle and not over 50mph. I try to find a winding trail so you engage/disengage the clutch alot.
1 - 14 of 14 Posts
