It has a vibration when riding, and the sled wiggles alittle bit when on ice, and it is studded. Not usre if its the boogie wheels or what it could be ? Any help is greatly apprecaited.
Check all the bearings, track tenssion and also inspect all the studs to be sure some aren't missing? Also check that it is aligned corectly (same gap on both sides of tunnel / track)
Okay, I've got the 1999 Jag 340's motor slid into the 1999 Z 370 chassis. Had to squeeze the expansion chamber section of the exhaust in there, but it seems to be fitting good enough. The Y pipes on both were different bolt patterns and one longer than the other. So I've got the 340...
Hello everyone! New to the forum and new to snowmobiling!
I recently purchased a 1980 Arctic Cat Jag 3000 F/C as a cheap project sled in hopes to use for ice fishing. I’ve bought new spark plugs, replaced the fuel line to the carb, drained all the old fluids in the sled and replaced them...
Im stumped. I have a 92 jag 440 that ran fine last year when put up. Started right up and drove off trailer this fall for maintenance. Took carb off and cleaned. Put back together and it will only run if i disconnect choke cable completely. That maybe I missed some dirt somewhere so did it...
Hello all,
I am used to working on classic fuel pump fed carbed machines, so this is a bit new for me. I am wondering where to start to diagnose the fuel delivery issue on this sled. It fires up for a bit with starting fluid, so good spark. I took the carbs out and cleaned what I could. I've...
