I own a 1993 Skandic II 377 with reverse, I have a problem that has me puzzled. The track has shifted to the left side of the machine (chaincase side). I went to a local dealer and they said the bearings on the drive axle were gone, I removed the drive axle only to find that the bearings on each side of the axle are still together and not bad at all. The drive sprockets are not loose.
With the drive axle in place there is some play back and forth and I do not see what is suppose to keep it from doing that
That's your problem. There is not supposed to be any play back and forth on the drive axle. You need to see how it's moving. Are the bearing holders broken? Are the mounts worn? There is something that is making the axle shift.
