The time is come to change out the drive bearings in both sleds. The 93 tcat and 94 wildcat. The bearings still look intact, but I dont want to run the risk of damage. Both speedo's have stopped working
Searched the forums but still a few questions remain.
- Should I change both bearings on the driveshaft? It seems like the bearing in the chaincase would have a longer life due to the sealed case/fluid lub?
- Should I go OEM: (1602-375 Bearing, 1 in. w/Lock Collar $30.30 ) chaincase side: 1702-179 KIT,REPLACEMENT BEARING-1in. $33.28 OR
go with Royal Distributing 2011 Fall/Winter Catalogue
Looks like they make kits for most arctic cat sleds.
While Im in there, what other parts should I replace to get the speedo working? So far, here is what I've got:
0602-154 Cable, Adapter $3.35
0120-247 . Bushing, Drive $2.97
Thanks in advance!
Thanks in advance!
