1 - 20 of 27 Posts
i have an 1988 arctic cat cougar 500 F/C and i finally got everything built and it revs mad high!! i rebuilt the carbs but nothin changed. cleaned everything and it wont work right. it starts it just revs so high. any ideas???
Sconnie
Yes. My idea is you have a serious air leak. From either the carb boots, or the crank seals. Spray starter fluid in those areas. if rpms go up, that indicates you have an air leak.
Rick
yeah do you know how to set the carbs?
my sled was doin the same thing.. I sprayed carb cleaner everywhere when the sled was running and didnt find any air leaks... Ended up being my throttle cable was to tight, and makin it rev high. So I adjusted that properly, and adjusted my idle accordingly, and now its alot better
Mach1 92' 617 & 94' 670
Should be either an idle screw that you can make adjustments to while machine is running, or there might be 2 screws (one per cylender) not sure how your carb is set with that machine.
Remember very slight adjustments on the screw, like a clock, only an hour at a time, very slight!!!
Discussion Starter #7
well i did have the carbs loose so i could pull them off without having to keep loosining them up so that could be a problem... but the slides in the carbs only shut half-3/4 of the way so they stick open and it revvs really high... idk what to do! i looked atta throttle cable today and it costs 115.00!!! so im not dumpin that into it if its not necessary...
If the slide needles have gotten gent, that can cause the slides not to close all the way too.
Is there any slack at the throttle block (1/8" between lever and block)?
Discussion Starter #12
its at my buddys shop and we messed with it last night.. was told it was the diaphrams but theres none on my sled obviously lol so another guy told me to use steel wool but i dnt want to mess anything else up!
If the throttle cable is too tight, it will not allow the slides to close properly thereby causing the condition you are experiencing.
I suggest that you address this before trying to run it any longer.
Mine still idles high at start up then lowers, I cant get mine perfect.. But plugs are both a nice color.. Maybe I should mess with my pilot screws
Rick
loosen the nut on top and bring the slides down till you have like a #2 pencil in there. thats about where it should be not half way down. and look to see like RJ said about the needle being bent.good luck
What nut are u refering to?
Rick
Oh I gotcha.. I think I have my throttle cable pretty well adjusted.. I jsut dont understand why wen u turn the choke off the idle jumps up then goes back down to 1.5... and there butterfly
Rick
no he said his slides are only half shut so i'd say he has slides. also mine does that also when i first take my choke off also. i think it is normal cuz all my sleds do it. but i have mine to idle at a grand.
My bad thought u were talkin bout my sled.. and maybe it is normal, just never really payed attention to it before.. I wont stress over it
1 - 20 of 27 Posts
