Yesterday ,worked on the drive shaft bearings , loosened track.& pulled secondary off noticed 1 of the 6 screws on the sheave face was missing, weired? After cleaning around the PTO side drive shaft bearing took speedo cable off ,cable spins freely.
Took speedo housing off & mini cable going into drive shaft , not broke nicely lubed, good. While cleaning the face of the bearing on the shaft ,the rag caught a edge of the outer bearing , the outer bearing race is cracked, wasn't noticable with the grease on it!? This bearing wouldn't of lasted very long !
Took chaincase cover off drained oil & inspected ,noticed chain tensioner roller was loose ,pulled out for inspection roller bearing shaft walked out of roller bearing holder ,one side is chewed & out of round ,will need replacing! That wouldn't of lasted very long either! Dam!
Will take pics today.
