I have my 97 XLT LTD put back together after doing crank seals and I still have the same old bog as before i did the crank seals..... The Mag side seal had a big chunk missing. I had a major bog to where on a stand, I could only get it to rev around 4500 rpm so I cleaned the clutches really well and now it goes past that. However, now it'll only rev to 6500 if I punch it then it'll bog back down and almost die. If I baby it, I can get it up to 8k rpm. Clutches are cleaned and the EPI TP-9 clutch kit is installed. Carbs have been cleaned and synced a few times and the track tension is what I think is correct. I tried unplugging the kill switch to see if they made a difference and it doesn't. Again, it really only limits the rpm if I punch it. Any suggestions? I've done a ton of reading on here but am running out of things to search. Thanks!
