I'm not sure what you are asking.. if you want to get the sled on it's side easier, like when you want to side hill, narrowing the ski stance to the narrowest setting will help that a lot. The narrower it is, the easier it is to pull onto it's side.
Is yours a 550 or the 600? The 600 has the RMK style rear suspension where the 550 has the Indy style parallel slide rail.
Either sled can side hill, it's all in developing the technique.
You got us both scratching our heads?
So you want to raise the tunnel to get the running boards Taller Or higher from the ground?
There could be holes in the tunnel to do that or drop brackets?
yeah im not so good in english im from Norway, but I've seen dan from nxt lvl raise the sled with ice age spindles but they are for axys chassis and I have proride
