1 - 1 of 1 Posts
Can anyone please help me?
I have a 96 T-Cat that keeps leaking oil out from the bottom of the water pump area.
After rebuilding the complete water pump twice and replacing the impeller shaft, once myself and the second time a dealer it still remains to seep or leak oil out from down around the bottom of the water pump.
It is hard to say if it coming from the bleed hole or just out through the pump casing.
Has anyone ever experienced a similar type problem??
Do you think this could cause a lean problem or melt down leaking from that particular area??
Any suggestions for a fix would be appreciated.
One pissed cat owner.
1 - 1 of 1 Posts
