Okay so i have a 2001 XC500 and im taking out the suspension to check all the bearing rebuild the shock and put new slides/ springs and 3 new wheels on and i cant get the two rear bolts out of the suspension they just spin is theyre a special tool you need to use to get it out? I got the front 2 out fine its just the back 2 arnt they just spin help?????????????
four gear pinned
there is a nut behind the tsl, you might need a flat wrench to get it.
four gear pinned
its like a 7/8 mabye? yes it is the nut you want.
_
(_)
I gotta have more Cowbell
I don't know if you have one or not, but I always have to use an air gun (impact gun) to get them out. And sometimes to put them in too. The inner shaft always spins in it's housing.
