I am thinking about upgrading my 1995 Mach Z rear suspension. It came with a C-7 and I want to install a SC-10 out of a 1998 MXZ. It is complete and in very good condition. Will this be a bolt in upgrade or will there be alot of fabricating to make it all work. The front has been upgraded by adding Olins and new light plastic skis. I also wonder about geometry changes or is there adjustments to make it work smoothly.:cool: Thanks for any info.
the front arm mounts the same as the C-7 but you have to move the rear mount, not sure which way (forward or back) i would try to find a SC-10-2 'cause it eliminates the upper carrier wheels
and would make it less involved to install, plus its a better version
than the SC-10 hope this helps.
