· Administrator
It's probably running a bit lean when cold. If it has carbs (not sure, not a ski-doo guy...) then adjusting the air screw or fuel screw to give more fuel at idle would help, as well as cleaning the carbs. If it's EFI... it could be a sensor that is having an issue and you may have to have a dealer look at it with their scan tool...
· Registered
ETECH is EFI, direct injection. Take it to a dealer (or anyone that services Skidoos) and have them connect up BUDS to it to get a readout. It will most likely be an injector issue. This can turn into a major issue so have it checked soon.
· Registered
Is the leak gas? If yes, then certainly it could be an issue. Could be that the seal on the top of the injector is bad. I don't know a whole lot about them, but had one pulled apart to just look at how it works.
