My friend has a 2004 FireCat F6 and i plan on spring ordering a 2005 SnoPro F6 EFI.... i was just wondering cuase i heard from a few peeps that studding the track might cause too much pushing and wont let you steer as good cause all it wants to do is drive forward..... is this true?? the snopro has a 1.375 inch track... if i add studs to that will i affect my steering?? what if i only put 48? or 96 studs??
Depends on the length of the carbides up front. 96 studs would be 8-10 inch carbides up front. If they only run a 4-6 inch on the ski i wouldnt stud it unless you get longer ones or youll push bad in the corners.
