I did not properly covert up the carbs on the engine and sprinkler water got inside and glued the round plungers to the wall of the carbs with lime and calcium build up. I already used some CLR to try and remove it but did not work as much as i needed it to. is there anything you guys know about that could help to clean it? I looked at replacement carbs but I don't have cash to replace all of them for $279.
