1984 Tundra
I picked up a 3rd party stator (Kimpex I believe), that has different color coding on the wires than the original.
I've been looking for a wiring diagram that I can match up. I had it together and actually could get the machine running, but it would often fire backwards, yes, backwards. In my troubleshooting, some of the wires broke off and now I'm faced with trying to match them up.
From the stator there are 4 wires. Blue, Red, Black, and Grey.
The black comes from the larger of the two coils and out.
The Blue connects between the two coils and then out.
The Red and Grey come from the same location on the stator, on the smaller of the two coils. My guess is that one of those would be the trigger and the other would be the cut-off.
The CDI box has 3 wires. Black/White, Black/Red, and a Black.
I'm guessing that the two coils are charge and trigger. Trigger being the smaller of the two.
So off the stator my guess would be:
Red = Cut off (put to ground to shut off)
Grey = Trigger
Blue = common
Black = to Coil
There is another red wire that comes out of the stator/generator assembly that is a ground wire. Then two wires, a Yellow/Black, and a Yellow, that come off the Generator.
Does anyone know if my guesses are correct and I need to know what the three wires to the CDI are.
Grey = Trigger
Blue = common
Black = to Coil
