hi, i was wondering if anyone could help me. i have an artic cat jag 340 and im haveing problems starting it. the spark plugs are not sparking. ive replaced the plugs and found that no power is going to the plugs. ive bypassed the ignition switch and the kill switch and it still wouldnt start. can anyone help me?
:confused:
When you bypassed the ignition how did you do it? Did you unhook the ignition then run a jumper from the brown striped wire to the solid black wire, so it completes the circuit? Because thats what I had to do..
