i imagine our snow is about like yours. 38* and rain at 5800 ft. glad i stayed in this weekend. snow layers are going to make for one helluva avy season.
yamaha used to have available a carb cleaner that you mixed 3:1 gas to cleaner. i havent a clue as to what was in it but it sure works. unfortunately, its no longer available. i blame epa regs on that. i searched the country a couple years ago and got the last bottle i could find from a marine dealer back east. if you ever go near an older or slower yamaha shop, stop in and see if there happens to be any carry over. black plastic bottle. read the directions, if it says mix with gas, buy it and send it to me.
this stuff worked so good you could mix a small batch, pour it into the carb via the fuel line, fire up whatever you put it in, bike, sled, atv, lawnmower, etc just long enough to suck it into the carbs, refill the bowls and just let it sit. shake the machine once in awhile to agitate. walk away, drain the bowls after a few hours or overnight, and bam, clean carbs! done from the inside out! the crap that came out of the bowls was amazing when drained. worked about 85% of the time. the really bad carbs still needed the extra touches.
unfortunately, there are no contents on the label and i have yet to find an msds for it. i just use it sparingly now for stubborn situations. small batches for extremely dirty parts.
