sled is getting fuel to the pump but does not get to the carbs , sled runs if primed and then dies afer the fuel we ad is gone out of carbs , where is the fuel filter located
Runnin Against The Wind!
Fuel filter should be located under the carbs. You probbally need to pull them off. Might be good to clean the carbs also while your at it.
the diafram in the fuel pump is ripped. take the fuel pump of and buy a new one around $100.00 canadian for the hole fuel pump. the fuel filter is not under the carbs it is an intank filter. so that won't be your problem.
Pull a line going to the carb off and pull it over. Fuel should pulse out of the line. If not, it's the pump. If it does, the inlet needle is stuck, or some other carb issue.
check to make sure the fuel pump pulse hose did not fall off the engine or break, it wont pump anthing if it dont' get a pulse from the engine.
